installation par la copie du serveur
SUJET: installation par la copie du serveur
   02/04/09 à 09:35 #2777
marcg
j'ai le problème lors d'installation des plugins avec la fonction folder () bad directory
j'ai installé joomla et jce par la copie du site serveur. L'installation s'est bien passée mais lorsque j'essaie d'insérer une image dans JCE j'ai les warning suivant
Warning: is_file() [function.is-file]: open_basedir restriction in effect. File(pluginseditorsjcelibrariescssplugin_ie7.css) is not within the allowed path(s): (d:/www/matthieudegeest.be/htdocs) in D: wwwmatthieudegeest.behtdocspluginseditorsjcelibrariesclassesplugin.php on line 429
Warning: is_file() [function.is-file]: open_basedir restriction in effect. File(pluginseditorsjcelibrariescssmanager_ie7.css) is not within the allowed path(s): (d:/www/matthieudegeest.be/htdocs) in D: wwwmatthieudegeest.behtdocspluginseditorsjcelibrariesclassesplugin.php on line 429
Warning: is_file() [function.is-file]: open_basedir restriction in effect. File(pluginseditorsjcelibrariescssupload_ie7.css) is not within the allowed path(s): (d:/www/matthieudegeest.be/htdocs) in D: wwwmatthieudegeest.behtdocspluginseditorsjcelibrariesclassesplugin.php on line 429
Warning: is_file() [function.is-file]: open_basedir restriction in effect. File(pluginseditorsjcelibrariescsstree_ie7.css) is not within the allowed path(s): (d:/www/matthieudegeest.be/htdocs) in D: wwwmatthieudegeest.behtdocspluginseditorsjcelibrariesclassesplugin.php on line 429
Warning: is_file() [function.is-file]: open_basedir restriction in effect. File(pluginseditorsjcetiny_mcethemesadvancedskinsdialogclearlooks2cssw indow_ie7.css) is not within the allowed path(s): (d:/www/matthieudegeest.be/htdocs) in D: wwwmatthieudegeest.behtdocspluginseditorsjcelibrariesclassesplugin.php on line 429
Warning: is_file() [function.is-file]: open_basedir restriction in effect. File(pluginseditorsjcetiny_mcethemesadvancedskinsdialogclearlooks2cssd ialog_ie7.css) is not within the allowed path(s): (d:/www/matthieudegeest.be/htdocs) in D: wwwmatthieudegeest.behtdocspluginseditorsjcelibrariesclassesplugin.php on line 429
Warning: is_file() [function.is-file]: open_basedir restriction in effect. File(pluginseditorsjcetiny_mcepluginsimgmanagercssimgmanager_ie7.css) is not within the allowed path(s): (d:/www/matthieudegeest.be/htdocs) in D: wwwmatthieudegeest.behtdocspluginseditorsjcelibrariesclassesplugin.php on line 429
mais l'image s'installe bien et je la vois à la fois dans jce et dans l'article.
Pas de connaissances en PHP donc je me tourne vers vous pour avoir une piste.
Une idée du problème ?
Merci pour votre aide
   02/04/09 à 10:28 #2783
 Re:installation par la copie du serveur
Au vu de l'erreur, l'appel de la feuille de style spécifique à Internet Explorer 7, je ne peux que te suggérer d'utiliser un autre navigateur
Sans plaisanter, tu auras toujours des surprises avec Explorer qui est développé avec ses propres normes, refusant d'adhérer aux standards et qui pose des problèmes depuis des années...
On voit dans l'erreur qu'il n'affiche pas le chemin correct car il n'y a pas de slash, je ne peux guère t'aider si ce n'est en te disant que quelqu'un a déjà signalé ce problème.
   02/04/09 à 12:15 #2786
marcg
merci effectivement cela marche sous firefox.
Pas une piste pour moi pour le message folder invalid path , il télcharge bien sur le répertoire temp mais n'arrive pas à créer les répertoires.
les répertoires sont ok sont joomla , safety est à off
   07/04/09 à 02:31 #2804
Les répertoires dans lesquelles il va installer les plugins sont dans jce.
Je ne sais pas comment tu l'as installé, mais si c'est par FTP, il peut être normal qu'il ne puisse écrire dedans depuis Joomla! qui passe par le mode HTTP; certains serveurs font la différence d'accès.
Il te faut vérifier que lors de l'installation les fichiers sont bien envoyer dans le répertoire plugins/editors/jce/tinymce/plugins
